Indy APIs
IndySDK includes several libraries used for kinematics and dynamics calculations, which can be utilized for the robot control. For details, see "AbstractRobot6D" (for IndyRP2, "AbstractRobot7D") in the path of "../NRMKFramework/Components/".
[Forward Kinematics]
- AbstractRobot6D::computeFK.
- Compute the task position and task velocity (optionally) from robot pose.
Parameters:
- TaskPosition: Construct a task position from homogeneous transformation (LieGroup::HTransform).
- TaskVelocity: Construct a task velocity from twist (LieGroup::Twist).
[Jacobian]
- AbstractRobot6D::computeJacobian.
- Compute the task position, task velocity, task Jacobian, and task Jacobian derivative.
Parameters:
- J, Jdot: "Task Jacobian" and its time derivative, respectively.
- TaskJacobian: 6 by 6 matrix (Eigen::Matrix
[Inverse Dynamics]
- AbstractRobot6D::idyn.
- Implement the recursive Newton-Euler method without gravity (optionally with gravity) for a given joint velocity and acceleration vector.
Parameters
- qdot: Array of the joint velocity values.
- qddot: Array of the joint acceleration values.
- gacc: Gravitation acceleration vector.
[Passive Inverse Dynamics]
- AbstractRobot6D::idyn_passive.
- Implement the recursive passivity-based Newton-Euler method without gravity (optionally with gravity) for a given joint velocity and acceleration vector.
Parameters
- qdot: Array of the joint reference velocity values.
[Gravity]
- AbstractRobot6D::idyn_gravity.
- Implement the recursive Newton-Euler method for gravitation for a given joint position.
Parameters
[Momentum]
- AbstractRobot6D::idyn_momentum.
- Implement the recursive Newton-Euler method for momentum computation for a given joint acceleration vector.
Parameters:
[Dynamics Parameters]
- AbstractRobot6D::computeDynamicsParams.
Parameters:
- M: Inertia matrix.
- C: Coriolis and centrifugal matrix.
- G: Gravity force vector.
- gravDir: Direction of gravity force.
[Admittance Trajectory]
- Calculate the desired trajectory based on a virtual physical proxy with the inertia, floating on 3D space.
- Use F/T sensor values to apply the external forces to a virtual proxy.
Reset admittance trajectory:
Parameters:
- delT: Sampling time.
Update admittance trajectory:
Parameters:
- TaskAcceleration: Construct a task acceleration from twist (LieGroup::Twist).
- posDes: Desired position trajectory calculated from interpolator.
- velDes: Desired velocity trajectory calculated from interpolator.
- accDes: Desired acceleration trajectory calculated from interpolator.
- tposProxy: Proxy's desired position trajectory.
- tvelProxy: Proxy's desired velocity trajectory.
- taccproxy: Proxy's desired acceleration trajectory.
- mode: 0 - not applied; 1 - applied for displacement; 2 - applied for rotation.
[Forward Dynamic Control]
- AbstractRobot6D::ForwardDynController.
- Provide "Forward Dynamic Controller" which uses "Jacobian Transpose" method in the task-space position control. It guarantees singularity-free task-space control.
Initialization and reset of Forward Dynamic Controller:
Parameters:
Control gain settings of Forward Dynamic Controller:
Parameters:
- kp, kv, ki: Position, velocity, and integral control gain, respectively.
Parameters:
- AbstractRobot6D: 6 degree-of-freedom (DOF) robot class which includes its states and API functions as members.
- JointMat: 6 by 6 matrix (Eigen::Matrix).
- robotNom: Nominal (or Simulated) robot.
- Mn: Inertia matrix of nominal robot.
- Cn: Coriolis and centrifugal matrix of nominal robot.
- Gn: Gravity force vector of nominal robot.
- PosDes, velDes: Desired position and velocity, respectively.
[H-infinity Position Controller]
- AbstractRobot6D::HinfController.
- Provide H-infinity position controller which is the fundamental position controller of Neuromeka's Indy7.
Initialization and reset of H-infinity controller:
Parameters:
Control gain settings of H-infinity controller:
Parameters:
- kp, kv, ki: Position, velocity, integral control gains, respectively.
Joint-space H-infinity controller and task-space H-infinity controller:
Parameters:
- qd, qdotd, qddotd: Desired joint position, joint velocity, and joint acceleration, respectively.
- pd, pdotd, pddotd: Desired task position, task velocity, and task acceleration, respectively
[Target Coordinate Setting]
- AbstractRobot6D::setTtarget.
- Set the HTransform matrix from last joint to TCP.
Parameters:
- R: Rotation matrix from last joint to TCP.
- r: Displacement vector from last joint to TCP.
[Reference Coordinate Setting]
- AbstractRobot6D::setTReference.
- Set the HTransform matrix from global origin to robot's origin.
Parameters:
- R: Rotation matrix from global origin to robot's origin.
- r: Displacement vector from global origin to robot's origin.
[F/T Sensor Coordinate Setting]
- AbstractRobot6D::setTFTSensor.
- Set the HTransform matrix from TCP to F/T sensor frame.
Parameters:
- R: Rotation matrix from TCP to F/T sensor frame.
- r: Displacement vector from TCP to F/T sensor frame.
[Tool Property Setting]
- AbstractRobot6D::toolWeight, toolXcom, toolYcom, toolZcom.
- Return the tool information such as tool weight and tool position.
[Home Position]
- AbstractRobot6D::qhome.
- Return the current home position.
